My discbine is 540. I generally run it with the 2-105. It just feels more nimble and is easier on fuel. The 135 is a Series 3 and has a quieter cab though.White 2-135 doesn't know the discbine is behind it. Need it for the 1000 pto.
1411 haybine behind my 4840. The 4250 was still putting on 28 and need to cut.What is the largest/highest hp tractor you’ve put in front of a sickle haybine?
Just curious!
I’m thinking about putting my IH 886 in front of my 7ft sickle Hesston 1110 haybine to cut a little hay - just to exercise both and for throwback kicks…
BTDT. Not something I wanted to on the regular, but the big tractor was the reliable one. When one of the smaller tractors crapped out you made due with what you had to get the job done.A guy not far from me uses a case 2670 for everything. He had a 930 he used for haying but it quit on him, so now everything gets done with the 2670. 9ft haybine, new Holland side delivery rake, 24T baler, round baler and even 6 row corn planter that I've seen. Been doing it for a while now.
Must be down to his last tractor. Running such a big tractor on hay equipment gets expensive over time. Hopefully, the AC works if on the tractor.A guy not far from me uses a case 2670 for everything. He had a 930 he used for haying but it quit on him, so now everything gets done with the 2670. 9ft haybine, new Holland side delivery rake, 24T baler, round baler and even 6 row corn planter that I've seen. Been doing it for a while now.
