4430 oil leak at steering arm
edkaczor
Have a 4430 that is dumping oil out of the steering motor (above front axle) along the steering shaft... all lines are good it's definitely coming from there as soon as tractor starts... dropped the 4 bolt cover and replaced seal and o ring .. started tractor and didn't leak for 20 seconds then started pouring again... thinking and internal leak but I don't believe there is pressure to the steering motor unless you turn the wheel?? Any input or ideas ? Thanks in advance
