International 584 wheel hub sleeve…
Massey_165
Replacing the wheel bearings on my international 584, I know the back of the hub has a sleeve, I got one out but it looks like there might be another piece in it, should that lip be there or should I try to get it out? You can zoom in on the picture and see a ring around the edge.
If you got the wear ring out , that’s all there is to it. Put new race in and install wear ring, the lip sets against back of hub, pretty straight forward
We did a CIH 495 not bar axle, outer axle bearing a few years ago.
We found one of third party repair manuals had the diagram wrong for the placement of the wear sleeve, see correct placement in photo below.
Your 584 has the bar axle so the placement is the same, you just don't have to take the complete axle trumpet off to repair.
Uh Jim pretty sure he’s doing a front hub
