Sorry Sean but the number 2 is trans pto, 3 would be live pto34022C is a 3400 with a gas engine, live PTO and an 8 speed transmission. So the transmission, where those numbers are stamped, was originally in a 3400. No way to tell if the rear axle was originally in the same tractor or if things had been swapped at some point. Maybe compare date stamps on all of the castings. If they are all within a month or two of each other then they were probably from the same tractor.
Being a 66 model the original chassis color for the industrial models was blue, all yellow chassis started in the early 70’sThere is blue paint under some of the yellow, not all
And to complete the picture 6B9C is the date code for February 9 1966 afternoon shift. The serial number is C130677 which fits in with the unit code (date code) and C means assembled in the USA. The 6C8 appended to the serial number probably is an additional date code for March 8 1966 but I've not seen this before, maybe Destroked has the story.Sorry Sean but the number 2 is trans pto, 3 would be live pto
Thanks for the sanity check.Sorry Sean but the number 2 is trans pto, 3 would be live pto
I’ve seen a number of early models with a date code at the end of the serial numbers, most always when this is seen there is no transmission date code on the left sideAnd to complete the picture 6B9C is the date code for February 9 1966 afternoon shift. The serial number is C130677 which fits in with the unit code (date code) and C means assembled in the USA. The 6C8 appended to the serial number probably is an additional date code for March 8 1966 but I've not seen this before, maybe Destroked has the story.
