International 856D oil leaks
dew67
I have oil leaks all over the rear of my 856D. Are gaskets easy to replace, or are there complications I don't know about? A lot of the oil seems to be coming from around the pto housing.
Need to be more specific. Oil coming from around pto??? Very unusual for pto gasket to leak. Are you sure the oil isn’t coming from under the seat where the auxiliary valves are
Upvote 0
I will be down there next week, and I will check and try to pinpoint leaks.
Upvote 0
Could be the rockshaft housing gskt like on my 806 . Maybe someday i'll fix it it's only been leaking since 94 no rush . Might even do the unlatching valve also , i fixed it once i think back in maybe 98.
Upvote 0
Pressure wash it, and, then run it. Get it hot at higher RPMs, and, check. Otherwise, you're guessing. Mark.
Upvote 0
