mike1972chev
Well, I sucessfully reworked the belt pulley bearings and seal a few weeks back. The outer bearing near the mounting flange had a few roller bearings galded,and of course, the original leather seal was shot! Where the seal rode on the shaft had a very nice groove worn in it, so it got an SKF Speedi Sleeve installed. It's all back together, and woks great now.No noise,no leaks.
Looking at all of the parts when I had it apart, EVERYTHING looked brand new, besides the outer bearing, and the leather seal, like it never had really been used much. I have read somewhere on line that that bearing going out COULD be due to leaving the heavy belt pulley installed when you are never using it??? Like it is added weight and "banging" the most lower roller bearing balls in the same spot constantly when just driving the tractor around causing the worn spots in them.
I have not reinstalled the paper pulley at this time. Has anyone else experienced the bearing issue due to leaving the pulley installed over years without belting anything???
