miner09
- Location
- Pattonville Texas
Can’t you get an extension on it? Take tire off give you room.
Once you get an oxyacetylene rig you'll wonder how you ever got by without it. It's an absolutely essential tool for working on old iron.I have yet to justify a good torch on my farm
Second on Kroil. Oops. Too lateKroil Give it a shot every few hours or so for a day or two. Its worked wonders for me.
Glad you got it loose. A little grease or never-sieze type product on the plug threads helps make them easier to remove the next time.Third day of soaking, impact drive and big hammer. The plug is out and axle is refilled. Thanks, everyone one for ideas. I have yet to justify a good torch on my farm and I lost the body man next door to a heart attack, he was a good friend for 47 years and we could fix almost anything in his shop. Working my sons into running the farm and it was the eldest that dropped the oil first, he was laid off by a company moving this spring so has run the cattle part.
that is some what true. I used to have a torch but used it so little and the cost of rentig tanks was to much. I have not had a torch now for over 10 years and do not miss it. I have learnt that if it needs heat I can get away with a small hand held torch, tiger torch or 2 electric heat guns. I have started using toilet bowl cleaner to desolve the rust and then a heat gun and wax is almost always enough. also I do not have days of patients so the toilet bowl cleaner works but reapply every 2-3 minutes and wash with wd40 before doing any wrenching. I am very carfull not to get it splashing where it might land on me or in my face. that is the worst part of acid. you must work slow and carfull.Once you get an oxyacetylene rig you'll wonder how you ever got by without it. It's an absolutely essential tool for working on old iron.
Never heard the TB cleaner trick but I will try it. And nothing against heat but I try to slow down. Bought new fire extinguishers and fire blankets this year. Jim very well could be right and heat could melt an o ring though I never thought of it.that is some what true. I used to have a torch but used it so little and the cost of rentig tanks was to much. I have not had a torch now for over 10 years and do not miss it. I have learnt that if it needs heat I can get away with a small hand held torch, tiger torch or 2 electric heat guns. I have started using toilet bowl cleaner to desolve the rust and then a heat gun and wax is almost always enough. also I do not have days of patients so the toilet bowl cleaner works but reapply every 2-3 minutes and wash with wd40 before doing any wrenching. I am very carfull not to get it splashing where it might land on me or in my face. that is the worst part of acid. you must work slow and carfull.
That's easily avoided by purchasing the largest tanks you can buy outright. I've never leased tanks, and I use so little gas I only need to fill them every five to ten years.I used to have a torch but used it so little and the cost of rentig tanks was to much
That is the type plug I expected. They can be a pain to break free.Morning guys, the plug was straight thread with a fine O-ring, I had been warned by the parts man at John Deere not to heat to hot or I'd be replacing the O-ring. The plug had a half inch square hole for removal or tightening, the surface was flush with the axle face. I didn't know if I could post pictures yet.
I second what Mark said. I don't use my touch much anymore but I had to replace the spindle on my LandPride finish mower. there was a threaded part on the old spindle that had not been off in over 20 years. Hammer, air hammer, pipe wrench and ever cussed at it. It would not budge. So a few minuets of heat from the rosebud and a hit with a 4 lb hammer off it spun. I would not want to be without it on the farm.Once you get an oxyacetylene rig you'll wonder how you ever got by without it. It's an absolutely essential tool for working on old iron.
