Hello. I have a 1970 John Deere A500 backhoe. It ran out of fuel and I've been trying to bleed the fuel system out. Unfortunately I followed Ais suggestions to take the top screw out of the injector pump because it said it was a bleed screw. Now Ai is saying I messed up by removing the screw and that it holds the guide sleeve in place and then because I turned it over trying to bleed it it is inside the pump and the pump needs removed to relocate the pin. Can someone shed a little light on this for me? I loosened the 3/8 nut and unscrewed the screw out by my fingers. There was no resistance and I screwed it back in by my fingers. Do I need to take the pump off and have the sleeve put into the proper position? I bled through the fuel filters then took the return line off the injector pump and had fuel there but barely anything at the injector fitting at the top. Appreciate any help. Thanks
