If it helps to find a used one the 3500 and 3550 industrial Fords used that same setup.My neighbor blew the seals out of his steering cylinder and if course all the oil out if the pump resevoir. He is desperate to get it repaired. He can't find a cylinder that matches what he has. Anybody know what he has from the pic??
Thank you BarnCatYou should just need a pick, seal puller, or a slide hammer and screw to get the ram seal out. The rod doesn’t come out unless you cut the welds.
I would love to know more about how you converted to hydrostatic steering. I have a 68 4000 and have a lot of ps issues.Standard US production 4000 power steering cylinder for 66/70, good used cylinders are getting hard to find, I sold mine after converting my 4000 to hydrostatic steering
The cylinder end seal kit is available aftermarket
Google CFPN3301A
