Cheap eBay carbs and fuel line repair
atlarge54
In the past couple months I've tried the cheapo eBay carbs on a Poulan leaf blower ($19), Echo leaf blower $12) and Ryobi hedge trimmer $15). So far they all worked except the hedge trimmer leaked like crazy where the lines penetrate the tank. In an attempt to fix it I removed the old carb inlets and inserted them where the lines enter the tank, so far so good. Only time will tell.
These kits seem like a decent option and some of them even include the stupid EPA adjuster tools. Hard to believe the cost compared to what a carb rebuild kit used to cost ( the miracle of slave labor). These kits even include a spark plug (I never use it though), extra primer bulbs, fuel filter(s) and spare air cleaner(s).
I've been noticing a trend lately on Marketplace where people are just throwing in the towel and giving up on the gas power tools and going electric. It is certainly easy to understand why.
View attachment 156589View attachment 156589
I have bought several of the cheap carbs and never had any trouble with them. 👍👨‍🌾
I might clean a carb on a small engine once if it obviously needs it. If that doesn't work, I go right to the chineseum carbs. Even at my cheap, old retired f@rt shop rates, I can't fix one as cheaply as I can replace it. Can't recall ever having one that flat didn't work. Did have a couple that didn't fit as advertised, but the vendor always took them back.
Chinese carbs and Tygon (or other ethanol rated) fuel line has rescued a raft of small engines in the last 10 years.
I have only used two on a small engines without issue, but we did make the swtich to 40v Ryobi.
I just put one on a 1949 IHC P/U that has been in storage the last 4 yrs. Fired right up with zero adjustments other than the throttle linkage, had to lower the pin at the card end about 1/8".
Batting 1000 with clone carbs (y)
I have used the Chinese built carbs with good results, but I priced a Stihl carb at the local Ace hardware and it was around $20. I was shocked to get the OEM for about the same price.
WOW I would say usually an oem is like $100. More than cheap item is worth.
I had good luck with a couple of them on lawn mowers, but last year I ordered one for my Honda 4-wheeler, and it would not start with the new carb. it was full of gas, nothing obvious, so I shipped it back for a full refund, and somehow, I fixed the old carb!
I just put a cheap carb on a BS 20HP V twin with a simplistic non bowl type el cheapo OEM carb. Seems the only thing keeping fuel in the elevated tank (on a riding mower) was a little O-ring in the carb......occurring after several years of ownership. With the new carb I also installed a shut off in the fuel line from the tank to the engine.....all I have to do now is remember to use it, both ways on and off.
