ii was hard to crank so we pull it.Any details to share? What is it doing or not doing when you try to use the starter. We can't see it to have an idea of the problem; we need full disclosure to properly help you.
nothing, that all I have to offer, the battery Good.
I can't seem to post pic.
"Hard to crank", can you explain that better? I didn't chase the history of your posts on this but you bought it in a non-running condition, didn't you?nothing, that all I have to offer, the battery Good.
Basic conditions for an engine to start to ask your self. First it takes compression! Next it needs fuel! Next it takes spark inside the firing chamber at the correct time.any ideas or suggestions !
runs good after pull start.
about 10 minutes of running !
tractor sat for long time with no love
We should clarify "crank" to avoid confusion as to the issue.nothing, that all I have to offer, the battery Good.
Is the impulse on the mag tripping/clicking when trying to start it?any ideas or suggestions !
Pull-starting generally creates a higher engine RPM than hand or starter cranking, effectively masking impulse/lag problems.I would guess that the mag (Fairbanks?) might need some love, especially in the setup of the impulse coupling. Pull-starting generally creates a higher engine RPM than hand or starter cranking, effectively masking impulse/lag problems.
I had a '38 which was crank-start only, and had no difficulty starting once the mag was set up properly.
