ford 4400 issues
Heber Taylor
I have this old 4400 backhoe that will not move forwards or backwards. I have checked the hydraulic fluid level and replaced the oil filter but it still doesn't move when the lever is switched in either direction. I heard there is something under the radiator that might be the problem but I haven't gotten that far yet. Any advice is appreciated.
thanks
thanks
Hello Heber, welcome to YT! Have you owned it longer and it just stopped working? What transmission does it have? 8 speed (4 lo and 4 hi), Select-o-speed Powershift(10 fwd & 2 rev) or mechanical shuttle (4 fwd & 4 rev.)?
thanks
Tell us more about it.
They put I think 3 different transmissions in that model
A 6F 4R with clutch pedal.
A 10 speed powershift (Select O speed)
A 4 speed reversing with torque converter.
Is it new to you or a trusty work horse you've had for years?
I purchased it a few years back, it was working fine but I let it sit for a year and now It doesn't want to work it is a 4 forward and 4 reverse
I purchased this from an old orchard, and it has had some use but motor seams to run strong, it has a 4 forward 4 reverse
