icehose
- Location
- Texas Hills
I was recently gifted a 1952 Ford 8N, Ser. # 410,998, that was last started more than 30 years ago. Biggest issue, so far, was the 6"-8" steering wheel backlash. Pulled left-side sector cover plate of the steering gear housing, expecting a slosh of old gear oil ... got about 1/2 cup of greasy water, no oil, and some nasty brownish sludge. Managed to flush out the sludge with mineral spirits. Reinstalled the cover plate (after figuring out how to reconnect the sector adjusting screw to the notch in the gear shaft) and adjusted the backlast down to an acceptable 1"-2" per the FO-4 manual.
Now, to fill the gear box with good Amsoil 85-90 gear lube - Oops ... cannot find the small Fillister-head screw supposedly located somewhere in the upper region of the steering column "tube and cover" (8N3509B?). In part, access to the steering tube appears to require removal of the instrument panel (and, perhaps, the "Support assy, Instrument Panel to Hood"). Unfortunately, at some now-indeterminable time in the long distant past, "someone" managed to lose the steering wheel cap nut, and, rather than find a suitable replacement nut, "someone" decided to just WELD the steering wheel to the steering shaft! Since the steering wheel cannot be pulled, the instrument panel cannot be pulled; since that panel cannot be pulled, there is no obvious way (at least to me) to fill the steering housing with gear oil.
Of course, I do realize that one option is simply to grind off the weld sufficiently so as to enable me to pull the steering wheel. As far as I can determine, that will require me to replace the entire steering column, including replacing bearings/seals/shims, and, perhaps, rebuilding the ball nut assembly. I am hoping that someone out there in forum-land knows of some esoteric trick to get that oil into that housing without incurring all of that expense and time.
