I’m working on a 350B with manual steering. We have replaced both steering clutches with bimetallic, overhauled all the linkages and replaced any part that was worn. The problem I’m running into is, if I set the clutch fingers using the ENGINE tab on the JD7 gauge (15/16 off drum) as stated on the book, I can’t release the clutch. By setting them at that adjustment there’s about a 3/8” gap between the throwout bearing and fingers with the fork released from the linkage. If I follow adjustment procedure, I run out of threads on the top clutch link adjustment and still end up with 14” of free play on the levers. By that point I don’t have enough travel left in the clutch for to disengage the clutch. I did try setting the clutch fingers at 1-1/8” above the drum, but even at full adjustment of the top link I still end up with 9” of free play on the levers.
Again, everything is tight and installed by the book.
Is there any case with the 350’s where using the steering tab (1.5”) is necessary?
