IH 584 pto not stopping with clutch
Massey_165
Just Bush hogged with my IH 584, I’m pretty sure it should have live pto? When the pto is engaged it doesn’t stop or slow down when I engage the clutch. Any advice on what to look at for this?
This is not the problem with your PTO, but a terminology thing. The clutch is engaged when it is driving the gear train (your foot is off the pedal). The clutch is disengaged when you push the pedal to stop the engine from driving the gear train.
Yeah my bad I did write it wrong, when I push the clutch pedal shouldn’t it also stop the pto? I know my Massey does.
The 584 has live PTO. It runs independent of the clutch. Has its own hydraulic clutch pack controlled by the valve controlled by the lever. You don't need to step on the clutch to engage or dis engage the PTO. Your Massey has non-live PTO, the clutch disengages and engages it. Mark.
Your Massey likely has the Live PTO which uses a two stage (dual) clutch. Push it halfway down and travel stops. Push it all the way down and the PTO stops as well. The 584 has the independent PTO, it is controlled by a hydraulic clutch that is operated by a valve totally separate from the foot/engine clutch. The PTO power shaft is driven from the pressure plate, so it turns all the time the engine is running.
Not all tractors are the same. Do you have an Operator's manual for the 584? It should explain operating the PTO.
Oh ok, yeah I just read the operators manual. I guess I’ll have to get use to that, I like how the Massey is set up but maybe I’ll like this way once I use it more.
As Dieseltech posted, the shift on the go without using the engine clutch and stopping/affecting travel. Running some stationary Pto driven equipment you can start and stop it without having to climb on and push the clutch, just reach the lever and move it.
Here we go with more terminology issues. The Massey Ferguson DOES have Live PTO by way of the 2 stage clutch. The International has INDEPENDENT PTO.
The common names for PTO systems used by most manufacturers are:
1. Transmission PTO has a single stage clutch and that clutch stops the travel and PTO at the same time when that single stage clutch is disengaged. PTO speed is proportional to engine speed.
2. Live PTO has a two-stage (aka dual) clutch. Depressing the clutch pedal about half travel will disengage the disc that drives the transmission for travel. Fully depressing the clutch pedal releases the disc that drives the PTO in that second half of pedal travel. Engine drive to the transmission is stopped when the clutch is pushed to shift the PTO. Massey Ferguson offered a ground drive position with the Live PTO. In Ground drive the PTO speed was proportional to rear wheel travel. It would also turn the PTO backwards if reverse was used while ground drive was engaged.
3. Independent PTO is usually operated by a hydraulic clutch pack, controlled by a dedicated valve. It is independent of the clutch that provides travel. It can be shifted in and out without touching the clutch pedal.
There were some other ways to have a live PTO such as the Allis Chalmers Power Director set up and hand clutches used by some manufacturers.
Some PTO powered implements I like 'transmission PTO'. For example, a post hole digger and a hay rake are 2 that come to mind. A mower of any kind, a baler, I want 'independent PTO'. Mark.
If you don't have manuals for your 584 there are free PDF versions for the older version IH 54/74 series tractors at the following link.
These are the UK versions of the manuals, if you live in the USA there may be some differences as the IH 74 and 84 series tractors were made in IH Doncaster, UK plant and shipped in a crate where final assembly was performed in the IH Louisville, KY plant using some parts that were common to the USA IH 404 and 504 models. If your 584 is a very late model it may have the "H" gear shift pattern vs the older "Z" shift pattern.
