my 1972 ford 5000 started to have random clutch problems as of lately
when going back and forth on the yard to work up the gravel it often doesn't want to stop the tractor when i press the clutch, after pressing the brakes pretty good I can get it to stop and shove it out of gear.
it's strange that 90% of the time the clutch works just fine
had a mechanic try it out, and he said he couldn't notice anything wrong with it.
is this a common issue with these Fords?
also, the PTO doesn't want to stop spinning, if I have the mower hooked up to it and start the tractor, then the PTO won't spin, but without an implement it'll spin
can't stop it with a piece of wood forced against it
thinking to replace the PTO brake, but here's my question: can I upgrade to a brake band?
mine has the older model PTO brake, so I would like to know if the brake band will fit, or does that take quite a bit of modification?
