Ford 841 Diesel Project
Well, it's time to get this tractor restored. The engine is disassembled and the cart tipped over and broke at least two pistons. I know nothing about the engine so I'm not sure where to start. I've done business with a local machine shop so a call to them is probably in order.
Do you have a service manual? Below is a picture of the one I use. It does a very good job of going through the disassembly, assembly, inspection, specification limits, various procedures etc.
Your tractor looks like about a 1960 841 , do you have a legible serial number to post , is the casting number on the right hand side of the block B9NN6015C ? There is two different Balancer Designs that are completely different as is the setup of them . I hope you have the later design . Do you have any engine building experience ? While these engine are not that complicated they do require special machine work to overcome common problems if you want them to survive .
I just ordered this manual. Thank you. I know the serial number was difficult to read, I'll cruise out to the shop and have a look.
Where did you order the manual from? I need to get one and an operators manual but I want good ones that are printed well
I found a printed one on ebay, also there available as a download -
Farm Manuals Fast. I probably got the wrong one as I see a 641 series one also? Ford 611 621 631 641 651 661 671 Tractor Service Repair Shop Manual Gas & Diesel on ebay.​
If you're looking for the manual I depicted, which I believe is the "terminal" manual for the For Hundred, Hundred-One, and 4-CYL Thousand Series the part number may help which is 40060090. Search for Ford 40060090 which seems to bring up many choices.
Yes your tractor is a 1960 built in the month of May . So if it still has the original engine in it , it has the better balancer assembly in it .
B9NN6015B from the side of the block
I just dropped the engine off at the machine shop.
Hey Dreamer , What did you tell the machine shop to do ? 1) the block , the crank , all 4 rods and the head should be checked for cracks . 2) make sure the connecting rod bushings and the connecting rod bolts get replaced. 3) the crank , the rods , the pistons , the flywheel all should be balanced regardless of having the balancer on the engine . 4) the bearings in the balancer are all going to need to be replaced . 5) .0015 is the maximum clearance for the main and rod bearings . 6) make sure you use the later Gear Rotor oil pump not the old style gear to gear oil pump . 7) make sure the crankshaft bore is true and straight . 8) make both the head and the block get resurfaced . If you want it to last more than 200 hours that’s the minimum you need to do . These engine are notorious for breaking crankshafts because of cracking problems , the connecting rod bolts break because they are same ones used in gas engines and are not heavy duty enough for diesel usage . The crankshaft can be reground up to .020 NO MORE ! They were Tufftride coated at the factory . The coating is .027 to .030 thick . Once it’s gone it’s no good for use in a diesel anymore . Do it right the first time and spend the money otherwise you will be doing it again when it blows up .
i'LL RUN THIS LIST BY THE MACHINE SHOP. Sorry caps were on.
