my tractor is randomly shutting down tonight as I'm mowing
starts to sputter and then kills the engine
tried to bleed all 4 lines on the fuel pump, after cranking for a long, long time(with intervals) finally 1 of the loosened bolts are getting wet from fuel
then after lots more cranking all 4 finally get wet, and that's when it fires up.
tried to keep mowing for another minute, and same thing happened again.
where do I start to figure out what's causing this?
fuel filter was replaced 20 hours ago
has fuel in the tank
in regards to the steering issue:
when the front of the tractor is down in a ditch, the steering locks up and steering pump starts to whine
