The Farm. Haying and Cattle Thread
It is not the other driver's responsibility to magically understand what you are trying to do beyond contine driving straight down the road.
Signal far ahead of any turn and tap the brake lights a few times before hard braking to signal your intentions to other drivers. Make sure turn signals and brake lights are visible in strong sunlight, not just visible if someone is watching closely, those are not the people you need to worry about, but firetruck-ambulance level visible that grabs attention from everyone including those who are not expecting any turns from you or are watching something else entirely.
Yeah, that sounds expensive and unneccesary, but two near misses is probably not the last. Upgrading lights and defensive driving are cheap if they prevent a high speed crash.
Explain why your driving in the middle of the road for 200 yards
If the mower to to wide for one lane holding over to the left is necessary but not in a truck
Swinging completely into the left lane to make a right turn has always been risky, I experienced this many times in my years of driving 18 wheelers. Turn signals are near worthless today as people either don’t use them or leave them blinking for miles as they drive down the road, I filled a car for or a mile with their right turn signal flashing before conditions allowed me the opportunity to pass, just as I started to pull out to pass they braked and made a left turn, with the right signal still flashing.
Extended signal distance is a invitation for that signal to be ignored, I generally turn on the signal a few moments before I start braking for the turn, if they don’t pay attention to that they were never going to. Minimize the the amount of time your making that left swing, ideally just as the mower/trailer/ long wheel base trucks rear end leaves the right lane the front of the tractor/truck should be reentering the right lane. Even then some impatient driver is likely to make a dash to get by, always look for that driver.
If the costumers drive way is that narrow talk to them about widening it if possible, a couple extra ft wider at the entrance can make a big difference on how much swing is needed
The road is already narrow. Lane and a half maybe. A glorified dirt road. a few houses on the road but every one knows why there would be equipment or hay being delivered. Since you didn't liked the 200 yard estimate. I am on the road for 520 feet after turning off the main road before I turn in the driveway. It is not flat so with the truck loaded with hay no need to shift again. There is no need to be in that much of a hurry that one should be contemplating passing on the right. Driving in the middle is an indication your going to turn. If that doesn't catch your attention than nothing will. We drive in the middle for all our left turns and still get idiots driving off the shoulder trying to get around. We live on a blind corner hill and always get passed. Never know what is around the corner. We hope not Amish. But someday it will be a loaded dump truck or log truck. I wouldn't want to be that idiot. And I am not telling a customer he needs to change his driveway. It works just fine. Should I tell Penndot they need to redesign the road I live on because 95% of the time I pull out in front of somebody. It sucks. Just what we deal with in this area. Just like you have your own issues to deal with in your area.
You're absolutely right about each having their own issues. I live on a very busy county hyway and have to turn left into my driveway with my farm equipment. People do all kinds of crazy things when I am stopped waiting for oncoming traffic so I can make my turn. Most common one is i start my turn and they want to go around me at the same time. They had been waiting behind me for 10 seconds and they are not going to wait any longer.
Just the other day I pulled out of in front of a pickup at my uncles. Not my normal driveway so was more attentive. My fault absolutely. I was so focused to the right because there is short view distance with the hill and people travel to fast. Quick glance left double check right and go. Well there was a dark truck no headlights and blended in the shadows. Of course he flipped me off even though he probably never had to touch his brakes. Problem with all the short sight distance once your in motion you might as well just continue than try to get back into reverse. Issue is the drivers you pull out in front of had great visibility the entire time and I'm sure thinks you are just ........ pulling in front of them. Nobody gets our perspective from the tractor.
A month ago had a flat on the 2350 and stole tire off 4430. Was surprised that it fit as good as it did and got me thinking again on upgrading to wider tires for better flotation especially when using loader.
Thought it looked a little goofy but I can get pass that. Yesterday I installed the new set and now have 2 spare tires. Nothing more efficient than having spare tires ready to go a moments notice. I actually ended borrowing my cousins off his disabled tractor for the past month. Good thing I did. I put the original one back on with a new tire and it didn't make 5 hours before flat. Turns out they pinched tube during installation.
I’m not a Deere person but I thought 4430’s had 38” rims and usually 18.4-38 tires or 20.1-38’s
Looks like that 2350 has 30” tires and wheels
Referring to the front tire I took off the 4430 when the 23 had a flat.
Never liked the skinny tires for loader work. It’s a back up loader but every time I have to run the grapple on it moving squares I cuss the ruts it makes cutting in. Been contemplating upgrading for almost 5 years but hadn’t decided in what tire size worked the best. Then with the flat this summer I got to see how it worked and decided to just bite the bullet and get it done. Now have 2 spare’s that fit across 3 tractors when the need arises. 4 tractors if I ever get around to swapping out the 4040 front end
Yea those 4 rib tires are nice fronts for a loader tractor.
I was daydreaming or something and was also looking at your rear tires and having difficulty understanding the tire change… blind to the obvious front tires.
Paul
My bad I was thinking rear
Are those 9.5L 15’s or 10.00-16’s
On a couple of my tractors I swapped out the 7.50-16’s for 9.5L15’s, same height but wider, on a couple of the others that had 30” rears I replaced 10.00-16’s with 11.5L15’s that are shorter but wider
10-16’s. My biggest concern was putting the wrong ones on and have the tractor sloped up or down.
Another round on the ground. 20 plus acres of first and 2nd cutting for baling on Friday. Starting the fields where logistics comes in as the fields have no customer access and all the hay needs to be hauled back to the barn for pickup. Doing both rounds and squares on first and rounds for the 2nd cutting. These are our poorer fields that really need to be addressed.
A field I rent the owner wanted a food plot put in. Weird piece 3.5 acres. Best part is he bought lime, fertilizer, seed and I take off the crop next year. Seemed like a good trade off just have to fit in my schedule. Plowed yesterday, very obvious it has been decades since ground has been moved. I could not do the entire field do to the roots that have grown in. Based on the fact I cleaned up a field edge of my own along trees with the plows and encountered very few roots this field hasn't seen a plow in 50+ years?
Field Agriculture Agricultural machinery Plantation Farm
Soil Agriculture Field Dirt road Plantation
Soil Groundcover Grasses Field Agriculture
I made one last pass to remove the dead furrow after this picture. As close as I was getting to the edge with the amount of roots I was pulling up.
I
Agricultural machinery Plain Field Agriculture Farm
Agricultural machinery Field Machine Agriculture Tractor
I
we took a ripper to the outside edges of our fields, made a big difference used to have 25 ft of dead space because of trees sapping all the water up around the edges, now green to the ripper tracks
Cleaned off, moved, and fertilized for the next round. 535 square, 39 1st cutting 4x4, 6 2nd cutting 4x4
Approx. 20 acres left of 1st cutting to do.
Poor rake is getting tired. A previous weld repair cracking again. Really need to upgrade.
Yield so poor only needed to make 2 trips.
A normal load is 28/36 with 2nd wagon
Haying on a pause here, nearly three inches of rain the last week. It was forecast so most of us sat out a few days before.
Looks like you put some work in.
Paul
Approx. 15 acres down. Little more 1st for rounds and our new mix for cattle getting done as baleage. Jap millet w/ cowpeas, soybeans.
Also straightened up a field edge where brush kept growing out.
That is some rich green stuff.
Here at the hay auctions, such stuff doesn’t sell well. Need to find private buyers that want what you are growing if you have anything but grass hay or alfalfa.
Was going to cut my second cutting, but now they moved the Friday rains from evening to forenoon rains, so no chance. The games of outguessing the weather. :)
Paul
Several folk grow teft around here, that seems a popular annual grass. It stays pretty fine textured.
Those big leaved annual grasses seem to get caught in a bad weather pattern and suddenly are huge stemmy things that are past their prime. I think even if cut at a proper time, folk around here identify it with being over ripe and woody and not that good. Even if it is.
Paul
Paul
Teff is a hard crop. Did it once. Timing is critical, it goes from good to see fast and if a hard rain it's on the ground flat. The next cutting of Millet I hope makes it to frost. Want it more mature. Hopefully doesn't get to mature by mid October and we freeze. then it can dry in the field. If I had a week of great weather I would have baled it dry and even made some small squares out of it.
