67 john deere 4020 steering valve
gidtex
Which screw get adjust to .003 which get adjust .001.john deere manual shows left side .003 right side .001.some people are claiming that wrong. Thanks
Do you have access to the special adjusting plate? Sorry but I don't remember which side is which & don't have access to a 4000 series service manual
SM-2039 for a 4010 states inlet valves are set to 0.001” and outlet valves are 0.003” with a picture showing inlet valve adjusting screws upper right and lower left.
TM-1006 for late 4020 describes the following:
Upper left set 0.003”
Upper right 0.001”
Lower right 0.003”
Lower left 0.001”
The one that keep collar .030 below housing surface.i don't. Will most likely make one.
I wish you the best of luck when adjusting those valves. Back when I served as a JD dealer service manager for 13 long yrs I had several so called mechanics under my supervision that didn't get those valves adjusted correctly on their first adjustment attempt. That is one of the reasons Tim S constructed his hyd test stand because R&R of that valve from tractor isn't a fun task.
I have had good luck with 2 heavy flat plates and feeler gauges until I bought the plate. I had issues with the first one 30 years ago at the dealer but success after that, while at the dealer the veteran mech's had me do them.
