JD 4250 fire board/fusebox location?
Pjones
I blew a fuse on my JD 4250 and cannot locate where the fire board is located. Can anyone enlighten me, please?
Remove cowling in front of instrument panel & circuit board will be visible while standing on floor/ground looking in SGB door opening. Be sure to check tightness of all nuts securing circuit breakers because those nuts have a long history of getting loose over extended period of time
Upvote 0
Thank you so much TX Jim for taking the time to help a fellow Texan. I take it that little black plastic box holds the circuit board? Thanks again
Upvote 0
Yes, the black box has the circuit breakers in it like Tx Jim said, pop off the cover and with the key on see if there is power on all of the threaded studs and also check the nuts for tightness. I was thinking circuit board also but it must be on the 55 series and newer.
Upvote 0
