bulletpruf
Working on a '67 350 Straight. I greased all the rollers with a low-pressure grease gun (used JD corn head grease) and oil spewed out of the back of one of the top rollers, so I figured I needed a new roller or at least a new seal.
I ordered a new roller from Broken Tractor and the website said I needed a new seal to go with the roller, so I ordered one as well (seal was $140!). Probably should have done some research before I fired the parts cannon because now that I'm looking at it and looking at the parts and service manual, I'm thinking I can just pull the top roller off, disassemble it, replace the seal, and reinstall the old roller on the old shaft with a new seal. Am I right here?
Here's the new one; comes with a seal:
And here's the $140 seal:
A few questions -
-Will I need to remove the entire assembly, including the L shaped support bracket that the shaft is pressed into? Or can I just disassemble the roller while installed and simply slide the roller off the shaft and replace the seal without having to remove the L shaped support bracket?
-Is there any trick to getting the old seal out and the new one in?
Thanks,
Scott
A few questions -
Thanks,
Scott
