Looks like you will have a super nice shop with lots of storage & work area you are lucky. enough room to have 2-3 projects going at same time out of the weather, get it weather tight & all will work out.A few random pictures.
I thought the same thing. 2x6's on their flats at what looks like 24" spacing and 8'-10' truss centres. Don't think I'd want to try that here. My guess is the OP is somewhere that doesn't get a lot of snow load. But if kit works, it works.Impressive how little is actually holding the beast up. After 70 years, no arguing it works.
We get blizzards in this part of Texas, 70 mph winds etc. So, really I need to look at some framing upgrades and whether this building is conducive to all this.I thought the same thing. 2x6's on their flats at what looks like 24" spacing and 8'-10' truss centres. Don't think I'd want to try that here. My guess is the OP is somewhere that doesn't get a lot of snow load. But if kit works, it works.
If you get snow loads, I'd want new steel on the roof. Especially for a lower slope like that. Old steel with a bit of surface rust (even after paint) has more texture/friction, and tends to hold a lot more snow. New steel let's it slide right off. I'd not be worried about the siding. Maybe paint it if you wanted it looking better, but even left as-is it'll probably outlive any of us by a long stretch.We get blizzards in this part of Texas, 70 mph winds etc. So, really I need to look at some framing upgrades and whether this building is conducive to all this.
And then repaint it in 5 years!I would repaint it
Foam won't stop leaks!! If anything, it will make roof rust/rot out more with moisture getting trapped between foam and roof tin!Find a Conklin roof contractor they can spray foam on the roof to stop leaks and add some insulation value to the roof
Do you really think it is practical to prep properly this size of structure to paint and actually have it hold up? I don't think so!6 years
You do not realize what the conklin spray foam does.Foam won't stop leaks!! If anything, it will make roof rust/rot out more with moisture getting trapped between foam and roof tin!
