How to Remove this Seal from Cylinder?
I removed the snapring, and below it is this metal(?) seal. How would i go about removing it, its hard and my pick cant really find a spot, would appreciate any help.
Thanks
That looks like an Oliver 550 (or GM/corvette) power steering ram, but from the angle of the photo without much scale I can't tell if it's bigger/smaller, etc. If so, there's 5 pieces including the snap ring. The actual seal is the last item removed.
If it is the same, here's a couple of videos that might help. I'd take a pick and start working that piece in circles until it comes loose, but I'd clean it really well first. That thing is a mess.
Thank you, i think it is similar so i might buy a replacement from one of those. I got the top one out with a drill and screw but the bottom one is tougher. If you per chance have a oliver 550 cylinder if you happen to have rod diameter that would be appreciated/
A drill and a screw then pull it out. But if it is leaking there is an oring/packing deeper which you need to totally disassemble. Waste of time to replace just that seal. The ram is in poor shape.
It is unfortunately, I would replace but jacobsen doesnt sell anymore and ive been trying to find a compatible replacement. Im thinking if i emory cloth it and just change seals I can deal with a small weeping leak for now.
I don't have one handy, sorry, but if that's what you're working with there's a chance a GM will work.
For what it's worth, I found the diameter on another forum for the OD of the Corvette rod, it's 9/16" (0.5625"). A new C2/C3 complete cylinder seems to be anywhere from $100-200, so I wouldn't go the machine shop route at all if it fits your application- which is what by the way?
Thank you i measured nad its 0.56 so it should be good. While I save up for that do you happen to know what type of seal I should be looking for as a temporary stop measure for a while? Thanks
You should be able to grab the rod and use it like a slide hammer to remove the seal.
From the looks of the rod. I would want to know what kind of shape the cylinder, piston and o-rings were in before I spent money on new wiper seals.
