Why do I have this?
Ultradog MN
Location
Twin Cities
Doing a deep clean inside my pickup and found this under the seat.
Dunno where it came from or how it got there.
In a box of odd junk from an auction?
I know it's a tachometer.
What do you do - use a stop watch and time it? I like it but it'll probably go into that drawer of odd tools that doesn't get opened very often.
I have one too, may have used it once! Ron MN
Daddy had one. Its still around here someplace. He used it in the Cotton mill to check the speed of some of the machinery. That was before digital everything. Your wristwatch (with hands, not numbers) must have a second hand, and while your wristwatch counts off a minute by the second hand going around its' face, you must also simultaneously count the times the little dot goes around. Then you multiply the number of times the dot went around by the ratio of the gears inside to get the rpm of the machine. As I recall it had a flat rubber pad and also a pointed rubber pad that interchanged on it.
"Not numbers": well actually, there were numbers from 1 to 12 arranged in a circle. Just not digital numbers.
Nowadays, there is probably an 'app' for your telephone that can do the same thing.
Digging around under the seat of your truck, it is a lot better to find a tach rather than an old girlfriends undies. Especially if the wife is nearby.
I have a vintage Starrett revolution counter, very similar, and I used it once to check the speed on an old hit-and miss engine. My dad had a Stewart Warner tachometer, for setting the cylinder speed on the combine, but I think it went with the combine.
