Montanaford
I need a 3 point side delivery rake. (Small irregular shaped fields). They are uncommon and expensive in Montana, Ive located a nice MF 25 and also an ok New Idea.
I know the MF were designed to run off wheel speed PTO, (which I don’t have) and might be unusable with 540 PTO. Is the New Idea the same?
The pulley ratios look similar to me. Or will I be able to use the MF with some messing around with pulleys? Looking for advice. Thank you.
