Dual loader cylinder repair
I am looking to fix the cylinders on my dual loader, looking for a place that sells the kits to fix them, I have the special wrench to take them apart with, thanks, rod
You need to remove the seals and what ever u need. Then take them to a fluid seal shop. All they do is measure them and hand u the parts. They have the calipers sitting right on the counter at each parts man. I do not know who deals in that down there.
You need the model number of the loader and which cylinders to start with. And the Du-Al kit number you are looking for if may help, you have it.
The store for this site sells some kits for Du-Al cylinders. Woods dealers, Messicks and Baum Hydraulics might be sources, but you will need to be ready to tell them what model loader you have, which cylinder you are working on, the barrel and rod diameters. Or pull it apart and take the parts to a full service hydraulic shop and see if they can match them.
Already mentioned, go to Baum Hydraulics, Redbook, download and browse Seal Booklet 1 - SEAL KITS FOR: Farm Equipment. There is a section for DUAL.
Baum Redbook
I have a older Dual I believe it's a model 250, the one with the single cylinder on the tilt. I believe I do have some extra packing kits around they are the ones looks like they were cut out of tire sidewalls. I can measure them up and get you the measurements if you're interested. I'll see if I can find them.
I want to thank everyone with their comments, I looked up Baum iron and found what I was looking for, they have a complete kit for my cylinders on my loader,again thanks for helping
