Bush Hog Disc
Very much dependent on the soil type. But a fair bit of HP to pull it effectively if running full depth. Offset discs pull way harder than regular tandem discs. And those Bush Hog built offset discs were waaay more heavily-built than most other offsets. If I remember right, the square steel that Bush Hog used for the gang supports was solid 4" square bar, whereas most other manufacturers were 4" hollow structural tube. The Bush Hog discs were very well built, heavy discs.
At a very (very, very) rough guesstimate without knowing your soil type, I think a bare minimum of 70-80 HP if you don't mind raising it up to not cut full depth in heavy soil. And you'd be much happier with more HP.
