Hello everyone,
Local dealer has a New Holland TL100A for sale that I looked at over the weekend. The tractor ran good started right up virtually no smoke (faint white smoke that dissipated quickly at what I would guestimate to be around 1200 rpm steady, no smoke before or after that range (temperature didn't matter hot or cold engine same, possible range when turbo is spooling up) and shifted through all of the gears fine, PTO seemed to turn on/off ok. Tractor was well used and not barn kept (faded hood and yellow/broken headlights). Before I spend $24k on a 22 yr old tractor I wanted some advice. Issues below:
1. Hours are unknown. Instrument cluster is inoperative for the tachometer and hours and other portions of the cluster do not illuminate. Instrumentation lights like the parking brake, flashers, diff lock etc. all illuminated normally along with the clock. Definitely electrical issues (supported below).
2. No power at all with the ignition key. Turn the key on and nothing illuminates, no crank etc. like a completely dead battery. They hooked up a jump box to the starter to get the cluster to illuminate and for it to start with the key. Likely why the cluster doesn't function properly. I'm not that worried about electrical issues as automotive electrical diag is what I specialize in and a tractor is much more basic than what I normally diag. I'm more worried at the unknown hours and later finding it has a ton once I do get it working.
3. No brakes, no mineral oil in the brake reservoir it was empty. I did notice some dampness around the rear wheel ends at the tires but no drips, more of a weeping. Dealer said brakes just needed fluid and to be bled which they would do before delivery. Auto mechanic stating the obvious me says if there are no external leaks with an empty reservoir the wet brake seals are leaking inside the differential. I'm worried they will add conventional brake fluid to swell the seals as a temporary fix or just add fluid and bleed which will eventually leak out instead of replacing the seals. Am I correct in that assumption? Although technically capable of doing that job myself, I'd rather have that fixed than deal with it in the near future. I'll be having that discussion with them this week.
4. Diesel fluid leak on the return side (fuel constantly dripping while running) and multiple hydraulic leaks on the lines underneath. I wasn't sure if it's coming from the fittings or from the valvebody because it was all wet. They said they would fix the diesel fuel leak and the hydraulic leaks. I'm not that worried about leaks as most are easily fixed and fairly common on older tractors. I'd be more worried if its leaking from the valvebody which is around $1,200.
5. Tires. All of the tires showed pretty decent bulges in the sidewall under every tread. Some dry rot but no crazy cracks. It looked like a sidewall of a car driven with a flat tire. I could flex them in and out by hand, diameter roughly that of a mini basketball. Dealer said that's completely normal for Goodyear tires and they all do that with nothing to worry about. This would be my first experience with metric tractor tires. None of my older tractors have bulges like that in the sidewalls. I'm not sure if the normal statement is accurate?
6. A/C compressor issues. Turn the A/C compressor on and belt squeels like a locked up compressor. However, I can turn the compressor clutch by hand without much resistance with the engine off. I'm thinking a belt issue but it felt tight with little flex which has me on the fence with that opinion. A/C will be a big deal for me farming hay fields in the summer with a full cab.
I know it's a lot to unpack, I tried to not be too wordy. Price point ok with the above issues or way off base? New farmer just getting into farming if it wasn't obvious
. Thank you for your help.
