Post driver hook up on IH 584…
Massey_165
How can I connect my post driver to my IH 584 and use the lever on my post driver? I’m able to use it now by keeping the lever on my post driver pulled back and using the lever on my tractor, but then I have to have someone on the tractor while I hold the post…
I get it, the valve assembley on the post driver doesn't flow through.
Might be as simple as changing the valve assembley on the post driver or replumb it so it flows through.
I had to changet the valve assembley on my wood splitter for the same reason.
It didn’t work either way, I’ll have to change the valve on the driver like others
Get the number off the valve. I think I have literature to confirm open or closed center. Ive been looking for a closed center valve for mine as most of my tractors are JD and only have one open center which can’t get NH to get back to me on where to dump the oil
Here is my thread from years ago
