Farmall 560 restoration or replace questions.
I would go to a welding and fabrication shop, not a machine shop. A machine shop won't do you much good on a job like that. If you wonder what they'd suggest, that'd be it.
Few more photos of repair area .
Please
The fender design you have is different than mine so I’d like to see what your issue is if you could.
Interesting post ,
I would take it to my friend that does hot air heating. He has the metal stock, the shear and the brake to make a new one in five minutes.
Afternoon,
Of course it is taking a lot longer to work on these fenders than originally thought, one thing I don't have all the proper tools. I put the rusted fender in a kiddie pool (electrolysis), after 3 days and cleaning - where the one brace support was really rusted out. I cut out the thinner spots making narrow rectangles and then did my best to weld some sheet metal in holes, unfortunately ended up using some automotive body putty to cover the rough spots. Still need to primer both fenders and then paint them.
According to my local fabrication shop to fix the fender would cost more than finding a good used one on the internet. Finding one fender for sale on internet is not likely, guess I could buy a pair and then try to sell one.
Afternoon,
View attachment 162653 View attachment 162652 View attachment 162654View attachment 162665
That looks great! I bet the rest of the tractor doesn't look brand new either.
suggestion use one of the metal preps phosphorus acid to stop the rust after the part is rinsed . This will prevent the rust , I use rust mort product.
I like to see the anode cathode hook up on the fender?
Also don’t do any hooking electrical up over the reservoir cause a spark cwill ignite thec hydrogens by product .safety
Did you use arm and hammer soda wash in the solution ?
Yes used Arm & Hammer baking soda Lowe's has it for .99 cents a box. I don't have pictures of the hook up, used copper wire to the fender mount and two pieces of an old T-post for Anode to pull the rust, cut notches in T-post and twisted the copper wire tight against the notches. Did not use any phosphorus acid (thanks for the tip).
