dick benson
UPDATE I pulled the valve cover and looks like some of the valves are stuck. I’m working on that. Also ordered plugs and new wires and a carb kit.
I picked up a Cub that sat a couple years.I emptied the gas tank and replaced the fuel bowl. New battery and cables. Has good spark coming out of mag #1 wire.
The spark plug wires are in the right sequence.
When I crank it I only get a couple pops out of the exhaust and sometimes some flames. Starting fluid in the intake doesn’t help.
Any ideas what’s happening, is the problem in the carb or the mag.
