NEED SEALENT FOR 5 GAL PLASTIC GAS TANK
Jbweld Tankweld product is gasoline resistant for this
Used it with some success for jobs like this and there’s a C farmall here with a fuel strainer held in place with it
If the area is flat, consider plastic-welding a patch over the break. You need a specific product for plastic and some plastics are difficult to get anything to stick properly, but for a large hole as you described, IMO plastic-welding in the best option
The patch and "welding rod" must be of the same type as the plastic tank. Many are HDPE, some are not.
Have a tiller with a wrap around plastic gas tank that is part of the shroud of the engine. A varmint decided to chew a hole in the tank and left me with a leaking mess when I use the tiller. Everything I've used eventually gives way and starts leaking again. I'm going to try to plastic weld it this winter. Any tips on the process?
Are we talking about a gas tank fixed to a machine or a 5 gallon portable can?
Also, I know nothing of plastic welding, but a quick harbor frieght search has them getting from 500-1000 degrees. I would think you would have to prep the tank like you would a metal fuel tank as in get all the fuel vapors out.
If its just a portable can just toss it and by another.
It could be that a number of us are near your age and living on social security, so it may not be just as you see it.
A good sealant that might hold for a while will likely run $10 maybe more. And it could take a couple tries before you get the results you want.
With a bit of shopping at yard sales, flea markets, Craigslist, and Facebook you can likely find a good used 5 gallon can for less than a sealant that will hold and seal your gas can reliably, or much less than getting the stuff to try plastic welding. There are a number of used cans advertised for $10 or less in those type places around here.
Just being realistic.
Are we talking about just a super narrow crack on the seam of the top of a tank at the handle or otherwise? If so, I say do what every other 78 year old guy would do and cover or wrap it tight with duct tape. When it bleeds through, do it again, and again, and again, so on so forth.
None of us passed the mind reading course. A slice on top is a lot different than on the bottom. I'd try some epoxy like JB Weld.
Sounds like the OP could be talking about a gas can. Seems odd for a gas can to have a cut. If the gas can is older it could be a brittleness crack, with more cracks likely to follow. If it leaks again the lost fuel could cost as much as a new gas can. I would replace it. Maybe go with a smaller less expensive can that is lighter and easier to handle. If money is tight maybe ask if family has one to loan.
Even if you don't learn a stinkin' thing..................at least he's entertaining.............Eh?
I had a new Midwest brand plastic safety gas can split at the molded seam along the bottom. Called Midwest and sent pictures, reply was buy a new one. It had 4G of gasoline in it when I sat it in the garage, it was empty when I picked it up. That gas literally went down the drain.
GOT A 1 INCH 1 1/2IN CUT IN MY PLASTIC GAS TANK. IS THERE ANY SEALENT THAT WILL WITHSTAND GASOLINE??
The hole would first need to be physically fixed. You could dry the tank out and then plastic weld a patch over the hole. Then when it's fixed line the inside of the tank with a fuel tank liner such as Red-Kote. The liner would last about 10 years and then would need to be stripped and re-done. After a decade the stuff would flake off like paint plugging the fuel filter.
