I’m looking for help/suggestions in trying to figure out what is going on with a Ford 5000 4 cylinder diesel misfire. It has a frequent misfire on one of the cylinders until fully warmed up then runs perfectly smooth (this only started this year). Mostly at the higher end of the RPM scale but sometimes at cold idle also. One of the times it was missing at cold idle and I cracked the lines to the injectors one at a time and found the #1 injector made no RPM difference with the fuel leaking out. The other 3 almost stalled the engine when allowed to leak. I changed out the #1 injector for new and it seemed to be a bit better at cold low RPM but still missed at higher. Swapped out the #1 and #2 injectors but the cold low RPM miss stayed with the #1 cylinder when repeating the leaking fuel test. It has a Simms-Minimec injector pump. Has anyone experienced this? I’m wondering if the pump has an issue but, once again, when it reaches full operating temperature it runs beautiful.
