kentucky gardener
that can help me setup a band saw when I get it
Setup??? It will very likely come with clear instructions for setup. Physical motion doesn’t transfer to well yet via the www, but we’re getting closer! Getting closerthat can help me setup a band saw when I get it
We have an older Craftsman, it's a good tool. When you get it home, check it over for obvious problems, plug it in and run it. If you have questions then, ask away, with pictures. Hopefully you will get the owners manual, I don't know if I have one, never needed it.its a Craftsman an older one.
Most Craftsman manuals can be found online. Get all the identification and the model number off it and seacrh for a manual for that model number.its a Craftsman an older one.
no its in pieces, before my grandpa passed he was trying to fix it.Most Craftsman manuals can be found online. Get all the identification and the model number off it and seacrh for a manual for that model number.
Is it assembled now? If so you should be able to move it without disassembling
Then you need to ID it and find a manual. Craftsman made/rebadged a number of different bandsaws and if it needs parts, it needs the right parts.no its in pieces, before my grandpa passed he was trying to fix it.
I too have an older craftsman bandsaw although mine came already assembled and running. Normally, I'm suspicious whenever something is disassembled for repair as in 'what wasn't right that it got taken appart'. That aside there aren't very many adjustments beyond blade tension and alignment on the wheels.that can help me setup a band saw when I get it
I found this online. It sounded pretty good for a short explanation.that can help me setup a band saw when I get it
Join Facebook group: Craftsman Tool Collectorsthat can help me setup a band saw when I get it
he had fixed it but never put it back together.His original post is a bit misleading. He has since posted the saw is in pieces; his grandfather (before he passed) took it apart to make repairs. KG needs to get the saw, find out what repairs/parts it needs, get parts, and make the repairs, before he needs to worry about set up. Repair and setup are two different steps to me.
"no its in pieces, before my grandpa passed he was trying to fix it." (your post #8)he had fixed it but never put it back together.
Is it 12” or 14”. They sold many many of the 12”. Both are good saws Blades for the 12” are expensive as they are not a common size. I have the 14”. Either are not hard to set up. You can download the manual once you know the exact model number. If you get stuck post on here as I’m sure we can help.
