M670 super lp follow up
Kent2255
I posted quite a while back about an M670 super lp that I was having a hard time getting started. Well, I got it going on Labor Day. I had to replace the regulator and carb then tune it up but I got to go for a drive that afternoon. I am running it on a grill bottle for now but suprisingly everything but the brakes work and they may be able to be adjusted, I just ran out of time. After I play with it some more and get it cleaned up, I plan on putting it up for sale
Nice job and that carburetor set up will serve the tractor well. Had a Case 400 with that setup, changed it back to Ensign. All was well but I'd swear the Impco ran the tractor more efficiently.
Thanks. I am pretty happy to hear it run and to be able to drive it. I am running it on a grill bottle for now. I have a good friend that has several lp tractors, he has a pump to fill them with. When he is done with harvest, I will haul it to his place and put some in the main tank and see if the valves hold🤞
