M670 super lp follow up
Kent2255
I posted quite a while back about an M670 super lp that I was having a hard time getting started. Well, I got it going on Labor Day. I had to replace the regulator and carb then tune it up but I got to go for a drive that afternoon. I am running it on a grill bottle for now but suprisingly everything but the brakes work and they may be able to be adjusted, I just ran out of time. After I play with it some more and get it cleaned up, I plan on putting it up for sale
Nice job and that carburetor set up will serve the tractor well. Had a Case 400 with that setup, changed it back to Ensign. All was well but I'd swear the Impco ran the tractor more
Thanks. I am pretty happy to hear it run and to be able to drive it. I am running it on a grill bottle for now. I have a good friend that has several lp tractors, he has a pump to fill them with. When he is done with harvest, I will haul it to his place and put some in the main tank and see if the valves hold🤞
In your spare time, check the main tank with either your air compressor or pressurize it with your grill tank and check everything for leaks. Leaks are easier to deal with before there's fuel in the tank.
I will try that sometime. The brakes need adjusted and the temp gauge doesn’t work but everything else functions properly. Heck, it even charges. I would like to keep it but need to move it to fund other ongoing projects. I will keep tinkering with it and fixing the small stuff. It is going to make someone a pretty nice tractor. I gave it a bath and painted the grill over the weekend
