Mark Poss
- Location
- Big Rock Illinois
Complete info gets a different answer, regular plumbing solder should work for that gravity line.Very low pressure, it’s a fuel line from sediment bowl to the carburetor. Thanks for the replies.
It works to attach steel mounting brackets on radiators. It can fasten fitting in gas tanks. It is used to repair holes in gas tanks. It has been used on those and more steel items over the years.I'm looking forward to trying 50-50 solder on steel. I've always kept an assortment of brazing,soldering, welding fillers and fluxes on hand and never occurred to me that plumber's solder sticks to steel.
Like I said, if it works for me I'll be embarrassed for not knowing 50 years ago. I can think of times I went to extra effort precuring and using oxy/acety to braze when solder would have been fine.It works to attach steel mounting brackets on radiators. It can fasten fitting in gas tanks. It is used to repair holes in gas tanks. It has been used on those and more steel items over the years.
They used to use lead as body filler before the advent of Bondo. Applied to the steel panel and used various wood paddles the shape the lead.It works to attach steel mounting brackets on radiators. It can fasten fitting in gas tanks. It is used to repair holes in gas tanks. It has been used on those and more steel items over the years.
