My advice,
Check with your county appraiser and ask what the taxes will be first.
I was going to build a 40x60 until I found out what the property taxes would be.
I then decided on a 30x40x14 ft and made a second floor.
My taxes are based on the square feet, not the height.
I also found out I couldn't build on a vacant lot.
So I attached the vacant lot to my house's property adjacent to it.
I highly recommend putting even on the pole barn and putting windows under the vented eves.
I had a 10x10 ft overhead door too.
Check with your building inspector to see what he wants.
If you don't require a permit, check with reputable builders for their recommendations on the correct materials to use.
For $16,600 an Amish crew built my pole barn in days back in 2019 before the massive inflation. I did the ground work, Labor for my concrete finisher $1000 Concrete was around $2600 for a 6 inch floor with wire and plastic underneath. I was told my pole barn would cost about 2x what I spent.
With ridge vents and eve vents ZERO condensation issues.
In my opinion windows are like advertising online: ROBMENOW.COM
The clear siding under the vents is plenty of light in the daytime.
Well worth every penny. The loft is a great place to store things. I can easily add more lost space when needed
I think you should look at the cost of using the best materials, not the cheapest materials. Only use CCA treated lumber for poles and any wood that comes in contact with the ground, Inspector or no inspector, built to the right way.
The cost of materials from Menards was more than what it cost me from a local builder who used Amish labor.
View attachment 97859View attachment 97860
