thebubbleboy
Success! Well, mostly. The parts came this afternoon so I assembled the 3 point components again with new seals and gaskets. Let it warm up a bit and everything functioned! Drove it around for a few minutes and then rechecked all of the fluids. The front end loader works perfectly, fast, smooth and powerful again. I plumbed the "T" tank line from the new hydraulic control valve back into the "suction/fluid in" line as the documentation with the new valve told me too. Previously it had been temporarily routed to the fluid fill hole just to eliminate a variable when we were trying to figure this thing out. Retested and everything remained the same as when the "T" line was put directly into the fill hole.
Now onto the last small problem. When the 3 point is raising, it is pretty jerky. It goes up pretty quickly but it is not smooth at all. Maximum lift height is set right as you can lift up the 3 point arms about 1/2" more once the hydraulics have lifted them to the max. You never hear it get up against the pressure relief valve or hear the engine bear down any. I ran it up and down quite a few times in case air was trapped in there somewhere but it didn't seem to improve.
If I can get the 3 point lift smoothed out, I can put this whole ordeal behind me.
Thank you for any suggestions. thebubbleboy
