Hi all, I recently bought a Ford 5000 diesel and have noticed that when I start it up cold, there is plenty of strength to lift a bush hog. However, about 45 minutes into a session I seem to lose all power. I put deadheaded a gauge on it cold and got about 2200 lbs and then did that again at 15, 30 minutes and it stayed pretty strong at 15 but was weaker at 30 minutes and then about 1000 lbs at 45 minutes. Increasing RPM had no impact so I'm thinking it's not the pump but more likely a pressure relief valve. I believe the valve is located under the drivers side foot rest under the pump. Wanted to get some feedback from the experts before digging too much deeper.
Thanks,
Thomas
Thanks,
Thomas
