step up sherman trans will not fit in 9n
mrhud
whent to put a sherman in and the bottom gear on the trans in the tractor is straight cut and the two shermans that i have has helical cut gears , where can i find the proper shaft for the sherman to fit that straight cut gear
this sherman was removed from another 3 speed 9n
you probably took it from a 2N the 2n (1942 to 1947) used 9n serial numbers hence your confusion here. but the 2N had helical cut gears instead of straight cut its the same 3 speed but with helical instead of straight cut.
Years ago a collector on a tractor site said Sherman made a version with a straight cut output gear, but in all my years working with Fords I have never seen one. So either they are extremely rare or don't actually exist. What you have to do is take the 9N 3-speed transmission apart and replaces the straight cut with a helical gear from a 2N. Then you can install the Sherman.
from the out side how do you tell the differance from a 2n and 9n transmission
You really can't. The helical gear came out around the time the model changed from 9N to 2N in 1942. The early 2N transmissions had the letters "HX" stamped on the transmission flange, but that went away after a while. Anything newer than 1942 had the helical gears. Any tractor without the safety starter button next to the shift lever would have had straight cut gears for sure.
As for parts, there are a multitude of sources on the internet. For new, this site sells parts as well as the New Holland dealer. An internet search for new Ford parts will yield many options. Can't give you any specific places since they compete with this site. For used, doing a search on the internet for used tractor parts will pull of some options, as well as any local salvage yards if you have them. And there is always eBay.
i have been an indipendant shop for most of my life so i know all the easy options and have a large phone book. i can find plenty of what i dont need, and everyone that i have called wants a part number and that probley means they have no clue what i a looking for . need to find that right guy out their i helped a freind of mine load 15 n tractors to go to scrap they all were pretty used up but heir was atleast five with shermans i removed one more of them at that time so i have two of them i cant use in this customer 9n
