4020 loss of engine Power
Dieseltech rebuilt an inj pump for my neighbor that ended with good results.
I'm waiting for Rich Norman, DeiselTech, to send instructions for shipment. I thank you for yours and others help. I could not have made this happen without the forum! All you guys are the best!
Sincerely, Robert Reid in Arkansas
Yes, your injector pump should always be put on a test stand after rebuild? You need to check specs of transfers pump pressure, CC output for all cylinders, leaks, and general operation before putting back on the tractor.. Esp the CC output is horsepower, which can be adjusted! Ask your tech if they run their rebuilt injector pump on a test stand? To me that is important to have done...
I got the IP to Richard Norman. If it's not one thing it's a dozen others. Today I removed the clutch access panel from the tractor belly and ball bearings started falling out. The bearing cage is completely separated. I know this means splitting the JD4020! I need to know the best place to buy parts. In the past I have purchased parts from Greenway, eBay, Steiner, Reliable Aftermarket Parts.
I need recommendations for the most reasonable, dependable, quality, one stop for all parts supplier.
Appreciate your input!
