Help with fuel leak on NH TC25D
Lefty53
I am posting to get help finding a fuel leak on a NH TC25D 4wd tractor. This tractor is owned by the church I attend, and I have used it (as a volunteer) to mow about 3 acres for 3 years now. I have zero experience with diesel. This leak started about 3 weeks ago, and oddly enough, it leaks while setting. It's pretty hard to tell, but it doesn't seem to leak any worse while running. First time I saw it, I had just topped up the tank, saw the leak, so I set a small pan under. In little over a week, it leaked about 1 gallon. I suspected the tank, but after closer look it seems to be coming from what I take to be either the fuel pump or a distribution point for the fuel lines to injectors. I will most likely recommend to the trustee that we need to take it to the man who has done the repairs on this tractor before, but wonder if anyone can give me any things I may be able to check first. I will try to get a picture tomorrow to post. I believe this is a late 1990's to early 2000's tractor. Thanks guys
Doug
Hard to see where exactly a fuel leak is coming from sometimes. I'd clean the area off real good and try and follow the trail of the leak back to the exact source. One hack is after cleaning spray some foot powder on the parts and the powder makes it easier to trace the trail to the source. If it has a shutoff at the tank I'd shut the fuel to stop it from leaking while parked.
Most likely source would be the fuel injection pump itself. There are slightly different versions used on that style engine regardless of country of origin. The pumps are well known for developing leaks in that area. You will indeed want to have it professionally repaired as it's not a homeowner type of project. You can (and should) clean off the top of the pump, blow it dry, then watch for the source of the leak(s). I expect you will find it's mostly coming out from under the flanges bolted to the top of the pump body.
Thanks guys. I will clean the area with some brake cleaner and see if I can see it. I will not be able to do this for several days. I do believe the plate bolted to the pump is a likely possibility. I will let you know.
Doug
I mowed again with this tractor. It did not leak as much as last time, I think because I did not fill with fuel. It had about half tank, I added little over a gallon. I then cleaned the area with carb cleaner. I looked very carefully and could not see it leaking. There are 2 hoses in the area where it had been leaking, but could not see any fuel there at all. I mowed 1 1/2 hrs and still did not see any leakage. I am pretty well done with this tractor for the season, but will watch to see if it leaks again. Obviously I need to resolve this before next season. I will post back here when I have anything new.
Doug
