Last week I was using my 2910 ford tractor, everything worked fine but i got a flat tire so i parked it for a day or two until i got it fixed. When i started again i drove it down highway i got main speed but felt like it could have went a little faster, then i went to bush hog i turned rpm up to 1800 but when i got in just a little grass not tall or thick at all never a problem before the rpm went down to 12-1400 and soon as i got out of grass it went back to 1800. the throttle never moved and it doesnt bog down like it normally does in thick grass with black smoke. I felt like maybe i had some trash in fuel but i always get fuel in trusted places. But i unscrewed under the tank for about 10 secs to let any trash flush out, then i unscrewed bottom of fuel filter in case that had trash or water and that flowed good, i opened lines by injector and all seemed to be squirting good.
I just changed injectors last year i think so they shouldnt be bad, after flushing line it seemed to be a little better but it still drops down to around 1400. Again it doesnt sound like its bogging down, its more like the throttle is turned down and then brought back up once out of light short grass.
I will post a video, i been busy with hay so havent had time to check anything else but any ideas what could be wrong?
im disabled and low on income so really cant take it anywhere or afford to have mechanic to come look at it, i have to fix everything myself.
What gets me is its not like its bogging down, with black smoke, it only drops down to 12-1400 and doesnt drop any further but goes right back up when im out of grass, any ideas or suggestions be greatly appreciated. i will tag a video i did my best to video what it was doing, hard to drive and video at same time.
