What Did You Do With Your Green Tractor Today?
Took the Super 88 and 4240 3 bottom to Parsons Farm plow day Saturday. My first time plowing. Everything worked as it should and had a great time. 5-6 tractors plowed.
My dad always complained when I or my brother didn't keep the place where you dropped and pick up the plow in a straight line on the ends so we could plow the ends off nice.
Awesome pics. Great colors of everything.
I have a question/observation.... What year is your super 88, ? When you get back to your tractor, look at the front right wishbone nut on top of the front axle, zoom in on the picture, you see a curved round extra piece right behind that nut. My 58' 880 has one just like that.
I'll try to add a picture Wednesday.
Thanks for sharing your plow trip. Awesome 👍 job.
GG Wes
GG Wes
Thanks! It’s a 55. That piece is a guard to protect a belt from rubbing on the edge of the nut while doing belt work. Pretty sure all WF tractors had that if you had a belt pulley. My 77 WF has it too.
Had a friend big her drone out yesterday and made a video of the 2255
That's done right. The plowed ground should look like a table top. No signs of individual furrows, or gaps when the moldboard throws the soil.
I see the slabs are a bit "greasy" Somewhat moist, but it's a fine balance. Too wet/too dry. It all depends on your soil, and when it reaches a point that you can actually plow it without tearing up your equipment. I'd rather go in a little wet, than mess with it when it's dry. Those slabs will mellow out over the Winter.
Wowsers. That's cool to learn something different like that.
Noticed last night in Chris Losey video of his super 88, has it too!
My 880 has power booster, no pulley.
I have added, we have added three to the fleet.
Stay tuned I'll try to get pics added when I'm home on Internet.....
Thanks for sharing. Have a blessed day! GG Wes
I knew the throttle on this tractor was made of brass, but as I was cleaning up some brake parts today, I found that this part of the linkage was also brass. Interesting that they stamped the Oliver logo here.
Air was calm today so I was able to get some spray painting and priming done.
After degreasing and applying rust resolver treatment on the engine area, got the primer on.
View attachment 167879View attachment 167880
View attachment 167881View attachment 167882
View attachment 167884View attachment 167883
I had a 77 with that brass brake linkage. The splines stripped out of it.
Continuing to get the parts and frame areas associated with installing the main front and rear seals, flywheel, clutch, transmission shaft and brakes painted up so all that can be done when I get my mechanic in. Got the inside of the front half of the chassis painted so I can get the oil pan in and not have to worry about working around that.
Got the first coat of paint on the engine and chassis today.
