Clutch stuck on JD 420
Dad"s 430 was stuck and an old JD service mgr. told him to get it rolling down a hill and with the tranny in high gear to pop the clutch. It worked.
Tie the clutch petal down and leave it for a week, if nothing, hold it down and have somebody pull you around in 4th gear, step on the brakes now and then.
I had a 420 clutch stick the day after I bought it at a farm auction.Messed with it for a week then decided to split it.It only took a couple hours to install a new clutch disc.It didn't have live pto,a lot easier to work on.
Our old 8N stuck every once in a while. Put it in high gear, tie the clutch down and have some one pull you (SLOWLY! <5 mph) in 5th gear while you bump the brakes occasionally. Figure 8's for a driving path seem to work a little better, for some reason.
Tried these ideas..news guys...decided to fool with my 420 today and readjusted on the clutch cam lobe....didnt stay there but when i was shuffling it around jockying into small door in barn and got rear wheel up against post and hit clutch pedal it would disengage the trans but when tracter isnt in a bind in reverse like that it still does nothing......any ideas? Seems like adjustment setting of some sort.
2014 thread, most have not signed in for a few years.
In your thread about this you posted you have tried adjusting the linkage and you said there was no change. It looks like you are going to need to split the tractor to see what is going on in there.
