Proud owner of a Case 830 CK DOM
Ok, thanks Jon. Tractor data says 9 quarts oil, 30 quarts (roughly) of coolant. Next fluids to be changed are power steering and hydraulic/transmission. Those will be trickier since the lines will have to be bled out, correct? The brakes might be fine for now.
Gene
After posting my reply, I realized my math is horrible, 9 qts = 4 gallons plus 1qt. As for the coolant I bought 7 gallons and have been filling before starting. Should it be filled to the neck and just below the vent/overflow hole or just above the core and before the neck?
To allow for expansion, just as it gets to the neck. May take another check and have to put some in if air gets traped and then bubbles out. Many have become alarmed when antifreeze dribbles out as their engine gets warmed up.
When I had it running and used it a bit the other day I kept checking the temp gauge on the dash and it didn't move. Once I get more oil put in tomorrow I'll run it again and see if the temp gauge moves. It has before the coolant flush and fill, I'm hoping I won't have to replace the thermostat and gauge as well. Next year I'll be looking to put new rubber on it, the tires are pretty weathered and cracked.
I've been trying to find a manual, operators/service, for my tractor. Going with my serial number 8323793, which manual would be the best/correct one? Finding several on ebay, amazon and other sites I've got a few options.
Gene
