Ford 641 won't run! Need Ideas!
My new-to-me Ford 641 Workmaster doesn't want to run and I'm running out of ideas on what is wrong.
PO #1 had put new points and condenser and a new carb on it and was supposedly driving it into town to get some gas in it. On the way it stalled and he couldn't get it going again so he sold it to PO #2.
PO #2 got it running but badly. Before he was able to do more he got sick and eventually passed away.
3 years later PO #2's son sold it to me and all the previous info is from his memory of the story so far.
I got it running badly much like PO #2 had probably done. It was flooding, misfiring and backfiring and barely running. So I took the carb off and cleaned out the old gas residue from 3 years sitting. Re-installed carb but same result. Next I checked the points which looked excellent although they were gapped way too wide so I adjusted them but the same result. Next I checked the timing which was much advanced so I set it back to 8*. Same result. But here is my first clue that I am repeating the PO's work, the timing mark door was already open and the 8* mark was clearly marked with yellow paint marker! Hmmm!
So the next step was a compression test. So they were (1-4) 145, 130, 135, 150. Not quite as close as I'd like but it certainly should run!
I've had the carb apart twice more to make sure everything was clear and the float was working properly and it all seems perfect. I also drained all the old gas and replaced with new. New plugs and made sure all were firing so the wiring seems fine.
So what am I missing????
The only other thing I can think of is the valve timing being out but I don't know how that could happen with gear drive, although I don't know the history of what has been done to it other than what I was told. The engine is pretty clean so it may have been apart, could it have been put together out of time? I'm stretching here but I can't think what else could be wrong!
I would really appreciate some other ideas from some of you who know these engines better than me!
Jim
Jim
Check your spark plug wires. I'd venture a guess they are out of order. Firing order 1-2-4-3, clockwise rotation of the distributor, IIRC...
Be a little more specific when you say it runs badly.
Does it smoke?
Is the air intake plugged?
You said all plugs are firing, but is the firing order correct?
Have you confirmed good gas flow?
Go back to the basics. If it has gas, spark, and compression it will run. Maybe not the best, but it will run. Start narrowing things down.
Firing order is right.
Good gas flow.
Air intake off.
Will run at slow idle but struggles and quits after a few (5-10) seconds, sounds like firing evenly (all cylinders) while it runs. Good draw on carb when cranking with starter. Half choke sometimes helps a bit. Opening throttle causes roughness, misfires and it dies. Sometimes will backfire through carb when it dies.
As above firing order of wiring
New condensers have been known to be bad.
Check distributor cap for cracks and carbon tracks.
I have seen nearly new spark plugs cause problems if they have been contaminated by flooding or some engines require a specific brand of plugs.
Take the distributor cap off and have someone crank the engine while you watch the rotor. Everyone says the rotor turns clockwise, but I remember an old Ford tractor rotor that turned CCW.
As I said, firing order is right, distributor cap appears to be brand new, condenser also appears to be new and I seem to get a very bright spark, the plugs were badly fuel fouled so I put a brand new set in. Nothing improves the situation.
Using Autolite plugs.
Try NGK plugs.
What is the condition of the plug wires? Are they metal core or carbon type?
Check the insulator in the distributor where the wire from the coil goes into it.
6-volt or 12-volt? Positive or negative ground. Generator or alternator (has it had a 6-to-12-volt conversion?)?
What is the condition of the rotor button?
Is the clip on the distributor shaft in place to hold the rotor button from flopping around?
When you say it sometimes backfires thru the carb. That tells me that you may have a valve staying open when it is firing. You sound as if you know your way around a engine. So lets just set back and have a beverage of your choice and think about this. You need gas, spark and compression to run. Start it and give it a LITTLE wiff of ether. Not a lot just enough to keep it running. say like a wiff every 2-3 seconds. That won't completely tell you what is wrong but if it then runs it will sort of tell you that it isn't electrical and is more than likely fuel related. Get back to us on what you find.
Try NGK plugs.
Plug wires are wire core and look fine
Cap looks 100% (like new, and maybe it is!)
12 volt negative ground (alternator)
Rotor button looks new and is tight on shaft, however it does not have a clip.
This is going to seem very elementary, but have you tried adjusting your idle and main jet?
