9N for military buffs
My guess is the holes were drilled to balance out the rims before paint and tires.
Are you suggesting they are there to “balance” the wheel like a car for vibration? I doubt that was given any consideration in the production of a tractor.
Edit to add: At least as far as a part that rotates as slow as the rear wheel.
A bit off topic cause it's not an N but here is one of my favorite military tractor photos.
It still sits on the flight deck of the USS Hornet which was sunk at the Battle of the Coral Sea in 1942. 17,500 feet below the surface.
Yes, that is what I am suggesting but I don't know if tractor rims were balanced during production of these later model Fords.
If they were balanced, it would be by removing steel by drilling holes in the manner you see on the photo I posted and not using weights such as lead as it was in short supply.
Again
Bet you could put a 2 lbs weight right at the inside of the rim where it bolts on the wheel and drive it at road speed and feel nothing especially on a steel wheeled machine. On a rubber tired machine you might get some sense of imbalance if you had an over-drive transmission that got you up to 25 mph or more.
Again
I'm not a tractor engineer nor did I work at the Ford 8N tractor factory in the tire and wheel department.
I am just speculating, if you think you know why those holes are there please share your thoughts.
